New 6.0 owners, need some tips.
#106
I want you to go into manage PIDs and edit the Transmission Fluid Temp (Method 2) and go down to the ODB Header and change it from Auto, or whatever it is to TCM and then go look at your Trans Temp. It will be lower, right now it is reading Coolant Temp. Guess they never fixed that.
I gotta' run, be back on when I can...
On Edit, and then make sure that is the trans temp you pick for your gauge...
#109
The ECT aka coolant looks a bit low still at 188ºF. Might be time for a new T-stat. Myself would not use
one from Motorcraft. They fail on a regular basis. One for International is the way I would go. Mine has
been holding up for the last 2+ years and I see 198ºF. The other option is one from Mish. But I think for
4ºF more the price is too high.
BTW the next time if there is one. Have the mechanic tell you what strategy you truck has. It's a good
bit of info to have so that if you do Have/Want to do some tuning.
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
#110
#111
If you post a list I can look them up. I have the 2005 PC/ED on disk
and can also post the pinpoint testing for things.
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
#113
This ?
What you call page 7 I call page 3. It has to do with how you have set the number of posts to show per page. Will post back what I find.
BTW don't mind Earl he is getting his back rubbed. One very happy squirrel. BTW he is a loving Squirrel.
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
#114
Ok so I cleared the fault codes And re ran them and it said 0 fault codes. So does that mean those are old codes? I read that somewhere in the forum, that you need to clear before reading them to begin with, but I'm not sure if that is accurate.
At cold crank:
Volts (CM) : 11.5
Volts(AD) : 10.8
What does that mean? Thanks.
At cold crank:
Volts (CM) : 11.5
Volts(AD) : 10.8
#116
At cold crank:
Volts (CM) : 11.5
Volts(AD) : 10.8
At cold crank:
Volts (CM) : 11.5
Volts(AD) : 10.8
We may do a bit of data capture just to see what is going on at a real cold start. But let's just start with what your FICM numbers are, have you found those yet?
Really things are looking pretty good so far, my ECT will hover under 190 for a bit until everything really gets all happy (and warm) then it'll sit around 190.4 unless demand is placed on the system.
Good job at clearing the codes, but let us not go off on that side just yet -- wanna' see what all is going on under the hood 1st
#118
Ok so it was only 5hrs sorry. Will check again tomorrow. It will be hard to do a full 24hr Though.
The ficm is not green on the gauges? I checked and they are still offline.
So with the codes does that mean I just reset them or were they old?
Good to know things are going in the right direction though.
#119
In OBD2 Adapter Settings:
make sure Faster Communication is not checked. You can try checking the Disable ELM327 auto timing. Let's see if any of that helps. I had a flaky adapter the first one I got like Sean had too...
#120
