Replacment drums availability
Ive got a closed knuckle dana 44 hd. Im in need of replacment drums and wheel cylinders. Does anyone know if there is a source for these in Canada. The previous owner replaced everything but the drums and now its been sitting so long the cylinders are shot to.
ALL 1955/65 F250 2WD & 1959/72 F250 4WD have 12 1/8" x 2" front/rear drum brakes.
Beginning in 1966, F250 2WD Camper Specials and F250 2WD's with 7500 lbs. GVWR have 12" x 2 1/2" front/rear drum brakes.
If 1968/72 F250 2WD's have optional front disc brakes, the rear drum brakes are 12" x 2 1/2."
Otherwise, all 1966/72 F250 2WD's have 12 1/8" x 2" front/rear drum brakes.
No 1964 F250 came with 12" x 2 1/2" drum brakes.
More info on brake parts needed.
I just got the drivers side apart and noticed there is a small cable that is broken. It looks like it holds the lever back that sits on the adjuster screw. Ive checked rockauto and napa it seems you can buy most of the parts separately and as a kit for this axle. I cant seem to find this little cable separately and it doesnt appear in the picture of the kit.
Hmmmm. That looks like the cable for the auto-adjusters. Only thing is I can't think of any 4x4 trucks that came stock with the auto-adjusters in 1961-1966. My 1966 2WD truck has them, but neither of my 1966 F250 4x4 trucks have them.
I thought they were only used with the newer designed 12" x 2 1/2" front/rear drum brakes for 1966 2WD, and then not all 2WD.
The part number for the Brake Shoe Adjusting Lever Cable Assembly is
C6TZ-2A178-A
Which, again implies 1966.
I have at least 9 of those NOS in the packages, but they also reproduce them.
1966 Ford Truck Brake Adjusting Cable New C6TZ 2A178 A | eBay
But, notice how it says 1966. I can't imagine this would be correct for your truck unless something has been swapped out.
Good luck!
Chad
C6TZ-2A178-A
Good luck!
Chad
1967/72 F250 2WD/4WD with 12 1/8" x 2" brakes.
C6TZ-2A178-A .. R & L - Front & Rear Self Adjuster Cable / Obsolete
1966/72 F250 2WD with 12" x 2 1/2" brakes / 1967/72 F350 with 12" x 3" brakes.
