1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Trans cooler lines in radiator
Old 07-17-2016, 09:08 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
I have Russell fittings and hose coming to hook up my new 6.0 cooler into my 5.4 powered truck. Have a question on the fittings on the bottom of the radiator for the cooler lines, first what is the 3/8" line called? Is it a double flare or what? And second question the female end that's into the plastic tank with the hex head does that unscrew or is it made into the tank? Trying to figure this out so I can overnight two adapters so I can get rid of the fugly hard line completely and use Russell braided line throughout my install
Old 07-17-2016, 09:20 PM
SuperDutyScaler
Old 07-17-2016, 09:23 PM
SuperDutyScaler
I think the 3/8 has what's called a double flare?
Just need to know if I can remove the female end thats against the radiator? I see they sell adapters but I need to know what I have to order the right stuff
Old 07-17-2016, 09:29 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
From what I remember those don't come out of the radiator.. When I did mine I used the factory 6.0 lines and used a stainless adaptor to go from the 3/8 to the 1/2...
Old 07-17-2016, 09:43 PM
SuperDutyScaler
Was it a hose adapter or hardline adapter?
Old 07-17-2016, 10:28 PM
Bigpipes 35
It was a hard line adaptor, Click on my pics by my sig I think there is a pic of it..
Old 07-18-2016, 08:20 AM
SuperDutyScaler
Ok that's a stainless 1/2 x 3/8 compression coupling for a steam system like a high pressure boiler. Where did you get the hard line for the 6.0 cooler? Looks like it was factory but our trucks didn't have that setup
Old 07-18-2016, 08:36 AM
SuperDutyScaler
Just called the mom and pop part's store I deal with all the time. They have a 100' roll of 1/2" trans line in stock! I told the owner Tony he needs to consider having hours on Sunday for now on LOL
Old 07-18-2016, 02:26 PM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
A 1/2" x 3/8" barbed fitting pair, black hose and the fittings off the cooler should be more then enough.
Old 07-18-2016, 04:45 PM
Bigpipes 35
The lines are from Ford and for a 03 up with the 6.0..
Old 07-19-2016, 11:00 AM
SuperDutyScaler
Ah so you bought them separate? I got her hooked up and running late night, can't wait for 3:30 so I can go home and take her for a drive!
Old 07-19-2016, 04:45 PM
Bigpipes 35
Yes bought them separate, I will wait patiently for a review..
Old 07-19-2016, 05:31 PM
SuperDutyScaler
First run is a big BUST
Old 07-19-2016, 09:12 PM
Bigpipes 35
Oh no what happened??
Old 07-20-2016, 07:17 AM
SuperDutyScaler
Where to start...
-My reverse engages fast now not 10 seconds late but it's very abrupt when it engages
-builder added a HD spring and this plunger thing from Superior in front of my .427 line mod and now slow speed shifts are so fast and hard the tires chirp and the truck just rocks/shakes/clunks
-half to full throttle shifts are like before the rebuild...they are somewhat firm but off, trans shifts but it like lunges forward but the shift isn't quick to engage fully, and it squeaks still during the shift, can't describe it I wish one of yous lived close to me so we could drive it and you could see first hand what I'm trying to describe
-the builder is blaming my transgo shift kit saying they are junk and after a few years the springs get weak from them and you get these issues? I called Brian from BTS but haven't received a return call yet because I want his opinion since I bought the kit from him and he told me how to set it up four years ago and the truck was AMAZING when I first did it
-now I'm wondering if the trans guy messed up the springs from the transgo kit and that's why I'm having a problem?
Quick Reply: Trans cooler lines in radiator
