High oil temp and gauge issue
Ok team - thank you all for the input today. Here's an update. Brian asked me to check to EOT and ECT cold temp this morning. They were 83/84 - so they appear to be reading the same at cold soak. For the defueling conversation from high EOT, I don't know what that would feel like at this point. It didn't seem to change performance as the temp increased - the highest I saw it go was 262 if I remember correctly. Based on the cold soak results, I didn't get two new sensors today but I may should have. I DID pick up a new factory thermostat that I won't be able to put in till this weekend. My son is driving the truck about 7 miles to work and he doesn't see any of these issues under that condition. So I'm going to let him keep using it till I get back in town later this week.
I am craving a validation of the real ECT. I may look into a way to get another temp probe into the system somewhere. It kills me not to really know the coolant temp and not knowing which gauge to trust, if any!
My first 185 Mishi opened at 196. They replaced it (lifetime warranty) and the second one is fine.
Cold soak - yes. 1 degree diff.
ECT on dash is steady but then appears to go hot really quick while pulling. After ding ding on dash, temp gauge rises to the max over about 5 seconds. Scan gauge shows steady at maybe 205. While watching the scan gauge, I could, occasionally, see it flash from 205 to 245 and back. It mostly stays at 205. Turn the key off and on causes the dash gauge to return to normal in the middle. Go down the road a little while and repeat.
EOT is not unsteady - just high.
Id try what Bryan said and swap ECT for EOT
maybe even give the harness wiggle test while someone watches the gauge
The High EOT could be the Bypass as already mentioned or a water pump not pushing enough flow
The SGII is reporting same as the dash gauge or there info comes from same place
The SGII is live data but has a 3-6 second refresh rate that's the reason you don't catch Both gauges jumping all the time
go into SGII user setting and set update rate to FAST
Your issue isn't too common but not unheard of either more folks have fixed it by changing the oil cooler bypass then those that had to do a Water pump & front cover from the posts Iv seen but I could have missed some posts No doubt
Verify your scan gauge settings
Tideman's last post was a very warn oil cooler bypass valve. This particular one cause high eots. However, as posted early on, oil cooler bypass valve problems are rare.
I had higher than normal eots when towing. Changed my bypass valve (by changing the oil cooler cover) and installed a new oil cooler. Dropped my deltas from 11 to 5. My deltas werent high to begin with, but when I towed my eot hit 256. I was doing 80 mph for 100 miles in 98 degree heat. I made sure I was using synthetic oil. It can take there heart better.
Changing the valve and cooler dropped my eot to about 245 towing in the same conditions. The old oil cooler bypass valve wasn't in bad shape. I'll mail it to you of you want it. Just give me an address.
Changed Tstats and bypassed my kitty and my eot towing hardly gets above 220 now. I speculated my TStat wasn't opening enough. Could have been a clogged cat, but it was pretty clear.
The difference between my temps and yours is my ECTs were always around 215 while towing. Now they hover around 208 while towing.
I was almost sure it was your eot sensor. Diasappointed to see it's not. Check your scan gauge program to make sure it's correct for the eot.
#30
