Which programmer / tuner for 1999 7.3L? need help
I know this subject is a bit subjective and has probably been discussed over and over again....Okay, so I bought my truck brand new back in 99'...it's got 130k on it now and I'm finally ready to give her a swift kick in the ****. I'm towing a big heavy boat and could use a little extra from her these days.
Obviously the Edge products are the ones widely marketed...but I know that means nothing really...so which one should I order? And, where should I order it from?
I'm towing a 10,000lb boat up some pretty steep hills...an extra 100hp and 200ftlb of torque would be a huge help.
I'd really like one that is capable of switching between modes while on the fly if possible
You can't tow 10k with the higher hp tunes like that. I think you need to do some more research. But I would get some custom tunes for an sct tuner if it were my truck. The switch on the the fly ***** are popular for the 7.3 but I'm not a fan of how they install. You lose the switch on the fly capability with sct though the new livewire has it for certain vehicles but you can get better tunes.
Really? I guess you're right...I need to educate myself more on these. So I have to ask; if not for towing, what would be the functional reason someone would need the extra 200ftlb of torque and 100hp?
Would the extra power hurt the trans under that kind of load?
On my 99 f250...I had the truck restored by a local shop that only works on diesels when i bought it. Cab, bed, engine and transmission removed. Sand blasted the frame and under the cab and bed. The engine didnt need a complete rebuild but everything external was replaced or rebuilt. I asked about a chip and he said he only uses TS. I had a six position chip..stock, high idle, 50, 75, 100 and 140 hp.
As a stock engine he recommended I use only the 50hp setting for most of my driving and towing. That 50 hp increase made all the difference in the world. It ran best in the 50hp position. 75 didnt do much more noticeable difference.
If you plan on using a chip the engine itself needs to be 100%.
When I bought my '02 F250 PSD right after 9/11 I did some research and ended up buying a BD Power "tow" chip. It gave you and advertised 40 hp and 110 lbs. ft. torque. As dtherrien mentioned, it really does make a lot of difference and a hell of a lot more fun to drive without fraggin the trans.
The guys at BD said that they also have the 80 hp and 100 hp chip but you couldn't tow anything due to the excessively EGT's. Also if you do get a chip invest in a set of boost and pyro gauges, specially the pyro so you don't melt your pistons on a steep grade.......very important gauge.
So I guess what I'd like is something reliable that isn't going to blow my truck up, something capable of switching modes on the fly...I like the digital gauges and monitoring capability of the Edge products. I've owned my truck since new and it has been very well taken care of...it is 100% stock mechanically with a lift, 20"wheels and 35" tires
I'd strongly consider the DP tuner. It is easy to add tunes later on and they can be customized to your truck. I've run it on two trucks now and I've been totally impressed. You will need gauges where as other tuners have gauges built in. Personally, I'd install gauges and run the DP Tuner. Just my two cents.
Questions:
Can I switch modes on the fly with the DP?
Could I install and use the Edge gauge / monitor or the like with the DP tuner?
Here's my baby:
When I was a member of another diesel forum, I was always told that it was a waste of time to go for big HP settings with stock injectors. The most that could realistically be expected would be around 40 HP with stock injectors.
