Leaking glass bowl, fuel pump?
Good news! I got my truck running from its own gas tank. I'm pumped!!
But, in the process of doing that, I have gas dumping out my fuel pump, all around my glass bowl. I'm guessing it's a new gasket that I need for that? A search suggests Felpro 773, but just wanted to verify with someone that that is correct?
Thanks guys!
Thanks guys!
I can not verify the number but I do know that area has always been somewhat problematic.. A gasket is not difficult to make out of some heavy cork gasket material that is readily available at any good parts house. Make sure the thumbwheel is tight. The leak may stop on its own when the gasket becomes soaked with fuel.
Thanks guys!
Thanks guys!
Doug
Cabledude
06-26-2013 09:22 PM
