1968 f250 power steering gearbox
#61
on
Front right disc is locked up now. Still rolls but you can't turn the tire by hand. I may have stretched the brake line when I was changing bushings but not sure. Guess I'll start by replacing those and go from there.
On on another note. What kind of replacement calipers could I use and where to buy them? Everything I seem to find online is the whole disc brake kit
Try opening the bleeder to let off ant pressure build up in the brake line.
If you did not rebuild the calipers then do so or get two replacements you can't or should not replace one side. You would not buy one new shoe to
wear to church with one old one or would you?.
Have you cleaned an lube the sliding guilds did you?
As this could be the problem with yours hanging up.
Orich
#62
Go to any parts store order them.
Orich
Orich
Rubber brake hoses on both sides are Ford part number C5TZ2078A.
The brake caliper was originally part number C8TZ2B120A. Replaced by D1TZ2B120A. Then this was replaced by D1TZ2B120B. This D1TZ2B120B Ford says was a kit. It has 2-1972/75 calipers and 2-special brake hoses to adapt to older Bumps such as yours.
Green sales shows both part numbers. If their D1TZ2B120B does indeed still have both calipers and both hoses in it, that would be everything you need. As Orich suggested.
Green Sales is 1-800-543-4959.
#64
#65
#66
How has the Redhead been?
The remaned one one I purchased through parts boulevard in Portland Oregon works well but has a small leak. I have to say they have bent over backwards and already have a replacement on the way - no questions asked. Can't say how pleased I am.
If this one leaks as well, they will refund my $$ and I'll probably consider the Redhead.
#68
#69
I don't think so. They are worried about old systems with dirty/contaminated fluid in them. Your system was together and working just leaking. And it sounds like you've flushed all that out of your system long ago.
#71
I must have been doing something wrong on the ones I did. I always had to change out the steering shaft and the firewall support bracket.
#73
So I've been thinking - I never had any problems with the original bendix box before I had to replace my ps pump. Picked a remaned unit up from oreillys and the bendix almost immediately had problems. So, I just thought it had bit the bullet. Then I track down one of the few rebuilt units available and boom, it starts leaking immediately as if the seals were blown.
Now im sitting here lookin at the new bendix they sent and I'm wondering - could I have the wrong ps pump? Could it be causing my boxes to go boom?
#74
I've a couple of different Bendix boxes and they have all leaked where the pressure line, the smaller of the two, threads into the gearbox. The tube seat appears to not be sealing to the flare fitting. I have installed a copper washer in between the seat and the tube with good results. I am wondering if this tube seat is separately replaceable like one from a master cylinder is. The problem is if I try and remove it with a large sheet metal screw I will definitely ruin it and it may not be available.
#75
Well, I didn't feel like ruining another bendix gearbox so I ordered another remanufactured ps pump from rock auto. This one had a couple seals that came with it and I used one on the smaller line you mentioned leaked often. After I put that in, no problems. The truck has been idle for about 5 months since the carb started leaking fuel and my power steering issues, so the drive around the block yesterday before dark felt really nice.
If if I were to do it over again, I would have just ponied up for the redhead rebuilt gearbox instead of the BBB one.
