Transmission cooler
Stewart
Only reason
The only reason I still have it is because I have other things on my Excursion "list of things to do" that have a higher priority.
3/8 to 1/2 adapter
I picked these up to connect the two different sized hoses from the factory cooler to the Dorman 6.0 cooler: http://www.ebay.com/itm/151294247465?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Just curious if anyone knew of any reason that these wouldn't be a good choice for transmission lines/fluid? I wouldn't think there is, but I thought I'd double check here.
I picked these up to connect the two different sized hoses from the factory cooler to the Dorman 6.0 cooler: 2 Food Grade Stainless Steel 3 8" x 1 2" Barb Splicer Fitting Reducer Adapter | eBay
http://www.ebay.com/itm/2-FOOD-GRADE-STAINLESS-STEEL-3-8-x-1-2-BARB-SPLICER-FITTING-REDUCER-ADAPTER-/151294247465?hash=item2339d70229
That's good to know. I originally bought some brass ones, but it turned out that the 1/2 inch barb wasn't. I don't know if it was a PEX fitting or what, but it didn't fit tightly into the 1/2 inch ID hose. Plus, the two sides were screwed together using an O-ring. Id rather have one solid piece and less chance for something to leak.
#29
I replaced our stock V10 2002 Excur 4 speed 4R100 cooler with the Dorman 918-216 31 row trans oil cooler that is used with the 5 speed 5R110W and it works great. We tow on the west coast where it can get up to 115 deg. The 5R110W cooler uses 1/2" tubing which reduces the cooler line pressure even though it is a much larger cooler. This allows the option of adding a 3rd cooler or a filter without increasing the cooler line pressure above stock. If the cooler line pressure gets too high the bypass tube can kick in.
schlepprock250
15
07-19-2009 11:15 AM
