2003 6.0 Delayed Acceleration
After running perfectly fine all day my truck will seem to bog down and when I press the accelerator the reaction is extremely delayed and tons of black smoke will come out of the tail pipe before the truck actually gains power and takes off. Any help or suggestions on what may be wrong will help!
{Ps the check engine light has been coming on but will turn itself off after the truck has been shutdown a few times}
On a 2003, an EGR delete shouldn't set a code. Even if a code was set, it wouldn't be an intermittent one.
Sounds to me like your turbo is sticking a bit. If you can, hook up to the heaviest trailer you can and take it for a good hard run. It will "excercise" the turbo and hopefully free it up some. If that doesn't work, it's time to pull the turbo and clean it. There's a few good videos in Youtube for cleaning the turbo.
lilshoe4me
07-02-2014 07:30 PM
