gas gauge
gas gauge
Hello,
Have a 63 truck,and just got it running and put gas in the tank and gauge does not work.The orange wire at the tank has a pulsating 12 volts at the sending unit.On the other end the gauge has a pulsating 12 volts volts on the black and green striped wire.So what should I look for to see what is right or wrong with gauge or sending unit in the tank.Thank You all for your help again.Greyhound
