Heater is running cold
Old 11-25-2001, 03:26 PM
TKE381's Avatar
TKE381
TKE381 is offline
The heater in my 1994 F-150 is blowing cold (luke warm at best). The thermostat is OK, the core is circulating and unblocked, and the switch is functioning correctly. What am I missing? Can anyone help before it turns cold this week? Thanks in advance.
Old 01-17-2002, 10:34 AM
slave2dafords's Avatar
slave2dafords
slave2dafords is offline
your problem is more than likely in the air box its self. the actuator that controls the "door" from fresh air/ ac to heat may be malfuntioning.. hope i am not too late with this info
Old 01-17-2002, 01:43 PM
2fords's Avatar
2fords
2fords is offline
Take a look at the firewall on the left side where the box comes through. There is a vaccum hose there attached to an actuator bar, make sure it's not hung up on anything, and the hose is attached. No cracks, etc... You can move the actuator but don't horse it too much, you could screw it up. Other than that, make sure the coolant is mixed right, and the door opens underneath in the cab. Be careful, it's always on when the key is on, and it can be sharp!
Old 01-17-2002, 03:45 PM
Pastmaster's Avatar
Pastmaster
Pastmaster is offline
ZombieSlayer
1978 - 1996 Big Bronco
12-09-2013 12:52 PM
ravens fan
1997 - 2003 F150
10-31-2011 10:37 PM
paulaconroy
1997 - 2003 F150
11-17-2009 07:17 AM
arieldg
1997-2006 Expedition & Navigator
10-14-2009 01:07 PM
toots
04-20-2005 04:54 PM
Quick Reply: Heater is running cold
