Bad fuel pump???
Old 07-13-2016, 10:43 PM
tstripes35's Avatar
tstripes35
tstripes35 is offline
Bad fuel pump???
Hi everyone,i posted yesterday about a stalling problem but I think I have it narrowed down, just want to see what everyone thinks. So I just got a new fuel pump about a year back. When I first got it it leaked fuel onto my driveway. Had it repaired, no leak. Now the truck stalls at low rpm or idle and it seems to be doing so more often. The funny thing is to restart it I have to put the truck in neutral, this is all while rolling by the way, and turn the ignition off, then bump the starter and she fires no problem. I had a hunch it's the fuel pump, before but now I'm convinced because turning off the ignition should reset the fuel pump correct? If I don't turn the ignition off she cranks away with not even a pop. Could the pump be faulty or simple not on right via gas line, ground etc? I appreciate my suggestions,
-Tony
Old 07-14-2016, 08:05 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,153 Likes on 911 Posts
So why start another thread about the same issue?
https://www.ford-trucks.com/forums/1...t-low-rpm.html
myonlytruck05
1999 to 2016 Super Duty
03-02-2013 02:29 PM
ccmeigs
1983 - 2012 Ranger & B-Series
10-31-2010 04:47 AM
FreeFall
17
12-22-2006 10:07 PM
acfr103
10-03-2004 09:30 PM
olddawg
06-23-2002 09:18 PM
Quick Reply: Bad fuel pump???
