Acceleration issue
Acceleration issue
1989 F-250 Custom V8 351W 5.8L
Vehicle starts right up but won't accelerate in 1st or 2nd gear. Has trouble reversing without dieing. I know the catalytic Convertor is clogged, is this the only thing that would cause this issue? Could the EGR valve be stuck open or closed?
Even if it's in drive and I hold the brake all the way and push the gas pedal RPMs won't go up. In park the RPMs go up just fine. Please help thanks
The cat gets red hot after a little bit of driving. I don't know how to pull codes even reading the guides on engine off key on type stuff. Paper clip and all that
Da 'Zone does for sure: Innova/Ford OBD1 code reader 3145- Read2Reviews onInnova #3145
I have seen Equus and Innova brand name used for the same tool.
Check your codes, definitely, but your cat shouldn't glow. Back pressure can affect intake, etc. so if your exhaust isn't flowing your O2 sensor isn't able to do it's job, or may not be working anyway, and it could be telling the computer to run rich. Richness = high fuel usage. If it's high enough you can smell it. Test your backpressure, or if you know the cat is truly clogged, replace it. You can also disconnect your exhaust and run it for a bit that way to see what difference it makes.
d_rich8807
09-21-2018 11:21 AM
misterbond
05-24-2017 05:53 AM
