BEST BRAKES EVER
BEST BRAKES EVER
I just wanted to say Ive completed my hydroboost swap on my 79 bronco.
IT STOPS GREAT! Way better than vacuum set up
I recommend it to any body with a vac booster set up...especially if you plan to tow.
I used a 05-07 f450 hydroboost unit, bought an adjustable proportioning valve. One small brake line that goes from master cylinder to adjustable proportioning valve. Two hydraulic lines. -6 an fittings. Power steering cooler. Some rubber hose for the return.
Best money spent but spent to much trying to figure it out right. So itll be better to see something someone already has.
Get them!
Get them!
Was going to make -AN hoses but stupid Fragola hoses use a different technique to make theirs. I wasted money with that.
I had to cut my brake pedal and bend the curve back straight some for the hydrpboost rod and weld it
Its what i found on ebay at the time...just what i dont like about it is the master cylinder brake ports are toward the engine.
Manfred , that's neat , curious to what $$$ you had invested in it , was the power steering cooler lines not sufficient enough?. Having 37 inch tires on my 1992 I am curious in doing this , will also tow a boat. My truck has antilock brakes front only . I presently have the fuse pulled. TR
About $30-$40 in adjustable proportioning valve
Saginaw pump maybe $100 or more
Hydroboost off ebay was $119
Had to buy new master cylinder for around $120-$140
-AN to 16mm adapters about $25
Cooler $20-40
Rubber hose and hose clamps $15
trick26
29
05-10-2017 08:51 AM
ManfredVonRichtofen
1978 - 1996 Big Bronco
05-11-2016 10:30 PM
hvb68
08-06-2013 04:01 AM
