Choosing a manual 4x4 transmission
Old 07-15-2016, 02:49 AM
Ken Blythen's Avatar
Ken Blythen
Ken Blythen is offline
Originally Posted by DrZoom
The more I read, the more I like the T19. Did they come in anything other than the f-series trucks?
https://www.novak-adapt.com/knowledg...anual/t18-t19/
Old 07-15-2016, 08:23 AM
Nothing Special's Avatar
Nothing Special
Nothing Special is offline
Originally Posted by bbf385
....T19 has synchronized first gear, which the T18 & NP435 don't, but the first gear is so low you will likely never use it anyway. T19 from a diesel would be OK as the first is a more usable 4.xx as opposed to the other three with 6.xx first gear ratios.
I've had an NP435 ('85 F-250) and a T-18 n('75 CJ5). The lack of a 1st gear syncro was occassionally an issue, but for the most part didn't really matter. You need to come to a stop to shift into 1st quietly, but since you only use 1st for starting from a dead stop it wasn't really an issue (off-roading in the Jeep it was sometimes a problem when I needed to grab a lower gear on a hill).
And the T-18 came with a 4:1 1st gear as well. I know Jeep used the close-ratio version. I think most other applications were the wide-ratio with around a 6.3:1 1st. But that is another close-ratio option if you want it and can't find a diesel T-19.
Old 07-15-2016, 09:53 AM
DrZoom's Avatar
DrZoom
DrZoom is offline
Does anybody have a good source for T-18/19 bellhouses? It seems the 460 4x4 is less common than I realized. A found one on craigslist 2 hours from me, but that's about it. I can order one online for 660, used, but that seems like an expensive gamble. There is a 5 year warranty though....
Old 07-15-2016, 12:34 PM
Nothing Special
There shouldn't be any difference in the bellhousings between a 2WD and a 4WD (but the 460/manual trans combo wasn't real common so they still aren't a dime a dozen).
Old 07-15-2016, 02:06 PM
DrZoom's Avatar
DrZoom
DrZoom is offline
460/manual is what I meant to say....found one an hour east of me for 400, including t-case. Would I be able to use the same transmission crossmember?
Old 07-15-2016, 07:20 PM
bbf385's Avatar
bbf385
bbf385 is offline
4found one an hour east of me for 400, including t-case.
That is a good price honestly. Check it for stress cracks. Not sure which case it would be, either a 208 or 1354 I would think.
Your trans cross member may work. Worst case you may have to slide it ahead an inch or whatever and drill a new set of holes.
Old 07-15-2016, 09:33 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
The last 460 bellhousings I had I sold for $400 Each
Stick with the zf5
Old 07-18-2016, 06:20 AM
DrZoom's Avatar
DrZoom
DrZoom is offline
I am having the ZF5 repaired but have decided to go ahead and buy the T-19 4x4 with the big block bell housing for $400. I will decide which one I like better and either sell the other or store it until I talk my wife into letting me build a big block galaxie.
chitlin1
Offroad & 4x4
62
11-08-2010 08:25 PM
Newcomer
06-14-2008 04:54 PM
95bronc5spd
06-13-2007 09:06 PM
Hiflyer746
10-26-2004 09:36 AM
maxine-70
16
10-09-2004 09:31 AM
Quick Reply: Choosing a manual 4x4 transmission
