Water Pump
Water Pump
Hey All,
Getting ready to do a water pump on a 08 6.4 about 100k on it. I'm a 6.0 guy and know my way around, jut want to make sure this is pretty straight forward and no special tools/surprises that you guys see.
Also anything else I should do while I'm in there, obviously coolant flush and a serp belt, but is there anything that is a common failure on the front of these that I should pay particular attention too while I've go it apart?
Thanks,
Sarge
Thanks,
Sarge
The fan clutch hub is left hand thread, meaning when you loosen it, you turn it in the opposite direction as you would when doing the same on a 6.0L diesel. These 6.4L engines like to eat primary drive belt tensioners so pay attention to its condition during belt removal. The biggest and single most important, is the front cover. They like to erode and cavitate in the area behind the water pump, so pay attention to its condition when you have the water pump out. The replacement front covers have a channel machined into it now to prevent a repeat failure. Usual symptoms for front cover cavitation on one of these engines, is coolant contamination into the crankcase. Good luck and have fun.
Cowgirl Caddilac
06-07-2013 09:22 AM
