Stalling at low rpm
Update: I was milling around the truck the other day. Still got no codes. But I noticed that the hose clamp that connects the gas line to the injector was broken. The hose was not coming off, but it was very loosely sliding along the fitting. I figured this could be causing air to get in the line for the rest of the lines look good. I got a hose clamp and tightened it up. Have had the truck out since for bout 30 mins of total driving and haven't even heard a sputter. Will continue to do short test drives to determine if this could have been the problem
This is the one i put on. As you can see the gose is now all the way on the fitting to the injector. There was a plastic one, almost like a zip tie on before but it was broken and the hose was sitting about a half inch lower(to the right) on the fitting.
Im not entirely ure that fixed it. ive since driven it another time (45 minutes total since the fix) and it still didn't stall. I will keep taking it on small trips and let everyone know if the problem persists.
Milwaukee1979F150
11-26-2008 10:13 AM
BOOYAH
08-02-2006 11:54 AM
