Fuel trim problem?
Fuel trim problem?
Started new thread continued from:
https://www.ford-trucks.com/forums/1...then-dies.html
OK heres is where I'm at now with 600 miles on engine, @ idle the STFT and LTFT stay arount 0 +/- 3 but at highway speeds 2.5k rpm @ 60 mph STFT is around 0 +/- 5% but LTFT is around 10 +/- 5%, engine sounds ok power is there have new 02 sensors installed also noticed MPG (16.5) is down from original engine about 3 MPG less . No codes.
Thanks
Ed
2005 Ranger 4.0
Thanks
Ed
2005 Ranger 4.0
Have a read here http://www.aa1car.com/library/fuel_trim_wellsmfg.pdf about fuel trim & if you don't have any set or pending trouble codes, at the articles end is a suspect list. Let us know what you find.
I can't open the file for some reason, but if you've spotted, or suspect something isn't right, hook up your Analog multimeter on the 1K ohms scale & measure the TPS resistance across the full range of travel, while looking for any drop outs, or unsteady regions. Resistance changes should be smooth.
thomastl
EcoBoost (all engine sizes)
08-07-2011 10:52 AM
bgchrs2001
1997-2006 Expedition & Navigator
03-15-2006 08:04 PM
