6.2 has some serious power! - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 07-12-2016, 11:57 AM
tincan1 tincan1 is offline
tincan1 is starting off with a positive reputation.
Hi all this weekend I put 3360 lbs of cement in the bed. I bought a pallet of Quickcrete...I have the 6.2 CC Shortbed F250 with the 3.73 gears. It sagged a bunch because the skid was too far back. But the truck from a dead start had tons of power. It was nice, the truck did not struggle with the weight. I just drove. It was actually a soft ride since the rear was so far down. I have the overloads and the sway bar. Very impressed. This weekend I'm picking up a TT that'll weigh about 7k. This truck will handle it without any issues. I'll probably have to use the cruise control to keep the speed down! LOL.
Jim
Old 07-12-2016, 12:07 PM
Chuck's First Ford Chuck's First Ford is offline
Chuck's First Ford is gaining momentum as a positive member of FTE.Chuck's First Ford is gaining momentum as a positive member of FTE.
Yes you will... (cruise control )
my winter trip... truck/motorcycle/generator/and travel trailer was 17,000 pounds at the start of the trip. WV,V,NC,SC trip .. hills and all..
the 6.2 Will do the work. even with the 3:73's.
Old 07-12-2016, 12:17 PM
I was thinking about sticking the bike in the bed as well, plus the Gennie, coolers, Kayak on the rack. It'll have everything you could possibly carry I guess. I get it that it's not as effortless with the Diesel. But this is the most powerful truck I've ever owned. It sure beats my 4x4 S-10 with the 4.3!
Old 07-12-2016, 04:56 PM
BeaverCrap's Avatar
BeaverCrap BeaverCrap is offline
BeaverCrap is starting off with a positive reputation.
They scream pretty good over 4K rpm don't they..... I tow a 9,500lb 5th wheel with a 1,200lb pin weight and it does very well....Towing that weight, I feel like I have way more truck than I need, and just enough engine... It's super stable and confident.....I miss the torque of a tuned Diesel, but the reliability and low maintenance of this truck was a really good trade off.
Old 07-12-2016, 08:48 PM
brickman brickman is offline
brickman is gaining momentum as a positive member of FTE.
6.2's are meant to be worked they are a truck engine, very reliable and strong, not delicate at all. I really enjoy using manual mode it takes me back to a stick shift mentality, where I can predict what the needs are before the truck gets there. I just love being able to work the powertrain with me in control
Old 07-12-2016, 10:14 PM
ATP Pilot's Avatar
ATP Pilot ATP Pilot is offline
ATP Pilot is gaining momentum as a positive member of FTE.
Quote:
Bingo...I pull my 12,000 lbs. 5th wheel that way. Works great, even with 3.73 gears....although I would rather have 4.30s
Old 07-13-2016, 10:43 AM
JIM_C's Avatar
JIM_C JIM_C is offline
JIM_C is gaining momentum as a positive member of FTE.JIM_C is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by BeaverCrap View Post
They scream pretty good over 4K rpm don't they..... It's super stable and confident.....I miss the torque of a tuned Diesel, but the reliability and low maintenance of this truck was a really good trade off.
Ditto. My truck seems to run better under load. Unloaded I keep trying to hot rod it but have to remember it isn't a Lightning.
My tuned 6.0 would flat haulAss but routine maintenance was expensive. Thank God it never blew up on me.
Old 07-14-2016, 04:04 PM
BeaverCrap's Avatar
I ran a towing tune on my 6.0 and it was a beast..... it would suck you back into the seat with the camper in tow....
Things started going bad on my NY to FL trip in March.... I noticed coolant and oil temps started getting very far apart....As I got further South and the weather got hotter, EOT and ECT would be 55 degrees apart from each other....I was running the truck on the verge of shutdown for 2800 miles....very very stressful.....It did get me home safely but the damage was done....heads lifted, oil cooler clogged, egr cooler ruptured...I couldn't believe it got me home.
It was going to be $5k to bullet proof it with me buying all the parts and my buddy in the shop hooking me up...... The truck was 11 years old, rusting out, had the usual 6.0 problems, and was RWD....It was time for a change....Traded for the 6.2 and I'm not looking back.
I have an epic road trip starting Sunday for 20 nights all over Upstate NY and New England....This will be the real test for me with this 6.2..... I think it'll do well.
Old 07-16-2016, 03:58 PM
The rock99 The rock99 is offline
The rock99 is starting off with a positive reputation.
Just finished a 5,000 mile trip from DC to Wyoming and back, about 1,800 miles there with a 10,000 lbs trailer and load, 1,000 miles while there hauling wood (up to 3,000 lbs in the bed) for a garage project, and then 1,800 miles back with the empty trailer. The total weight of truck and loaded trailer on the way out was 18,740 lbs. no issues with the truck at all, and other than the gas mileage, I couldn't even really tell it was there.
2016 6.2 CCLB F250 3.73 gears
Old 07-17-2016, 05:46 PM
mattn03 mattn03 is offline
mattn03 is starting off with a positive reputation.
How was your MPG loaded and unloaded? Is yours a 4x4?
Old 07-17-2016, 07:35 PM
Yes, it's a 4x4. Gas mileage was about 6.5 mpg on the way out, and about 7.5 mpg on the way back. I had limited time for the trip so I went 70-75 mph both ways, if I had more time to go slower, I'm sure I would have done better on the gas. Trailer weighs around 4,500 lbs empty.
Old 07-18-2016, 12:01 AM
RainDesert's Avatar
RainDesert RainDesert is offline
RainDesert is gaining momentum as a positive member of FTE.RainDesert is gaining momentum as a positive member of FTE.
3.73's are simply brutal for towing mpg. 4.30's are the way to go on the 6.2. From my research and reports I have read, the 4.30's will add at least 1 and likely 2 mpgs.
Old 07-19-2016, 10:41 AM
Squisher's Avatar
Squisher Squisher is offline
Squisher has a good reputation on FTE.Squisher has a good reputation on FTE.
Man you're killing me with these 4.3's comments. You gotta stop, before you cost me money. Lol.
Old 07-20-2016, 07:45 AM
Ron94150's Avatar
Ron94150 Ron94150 is online now
Ron94150 has a very good reputation on FTE.Ron94150 has a very good reputation on FTE.Ron94150 has a very good reputation on FTE.Ron94150 has a very good reputation on FTE.
^^^^x2^^^^, and I'm reminded every time I see my dads regular cab truck. He pulled out from my house the other day and hammered it. The regular cab that is minus one resonator sounded great, and with 4.30 gears took off very well. Bad part is, his initial order was 3.73's, I talked him into 4.30's. Just being a good son I guess, but I'm so jealous. Im hoping he decided he doesn't want them, then we can just swap axles, but I don't see that happening.
Old 07-20-2016, 08:40 PM
WyoBull's Avatar
WyoBull WyoBull is offline
WyoBull is starting off with a positive reputation.
Getting the 4.30's was the best decision I made when ordering my truck and I did a lot of research on this site before making the decision. It was also the hardest decision but after getting my truck and driving it for a little while, man, I could not be happier!
Does the 6.7's reliability really ruin the fun? 2009kr 6.7L Power Stroke Diesel 94 04-14-2016 05:54 AM
5.4 vs 6.2? rb8484 1999 to 2016 Super Duty 22 11-07-2015 12:14 PM
2016 f350 dump truck with 6.2 gas update ironman1977 1999 to 2016 Super Duty 2 08-17-2015 09:53 PM
Joined the 6.2L line HorsehaulerTN 6.2L V8 4 06-02-2015 07:34 AM
Anyone with the 6.2 Motor? weazel 6.2L V8 11 07-28-2010 08:32 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
