Disconnect
Disconnect
While trying to find the source of an oil leak, I was cleaning oil off the hoses from the turbo and found this loose wire tucked underneath. I don't see any obvious place to connect it. Where should it go?
Arrow points to disconnected connector
Wire colors seem to be white with red stripe and black with pink or purple stripe
Welcome to the site, Brian-C.
I agree with what was stated already. If you live in a warmer climate with mild winters, you probably won't ever need the EBPV connected. The EBPV is one of those things we could probably live without, but it's there for some reason, (emission requirement?), anyway. It may through a code, but leaving it disconnected won't hurt anything.
No, that is NOT true... throttle position, oil temp, and EBP determine when the EBPV activates . A plugged tube will never drain your battery.
About the connector: I read somewhere that the EBPV is sometimes used as an exhaust brake. When I bought this truck 5 years ago, it came with "O&C Powerbraker" aftermarket exhaust brake installed. I see a cable connected to the EBPV (apparently - it's on the pedestal and would mate with the disconnected cable). That cable comes from the cab where the exhaust brake switch is.
I've never used the exhaust brake because I thought something bad might happen. What are the pros and cons of exhaust brakes? Any cautions about using them?
I use this truck mainly to haul a 9000+ pound fifth wheel trailer, if that has any bearing on the situation.
The ones known for dusting engines are the orange tube between the trubo and air filter. the clamp on the turbo end cuts through it and the turbo sucks in dirty air. I've still got them on all my engines, but i also look at them when I change the oil and there still solid.
Dstosh
10-06-2016 07:03 PM
andysam
01-18-2014 10:05 PM
Ed in Maine
11-26-2007 01:33 PM
