Front Grille Trim Parts
Good Morning Guys!
I am putting the front of my 66 F250 Flareside back together.
I don't have a parts list but do have a repair manual.
Does anyone have the parts number for the Bolts and screws needed to reinstall the Grille, Headlight bezels and the turn signal trim? My local ford dealer doesn't have the ability to look up parts this far back. Alternatively, where can I obtain a parts list?
Thanks in advance!
Thanks in advance!
I thought Number Dummy or TA455 would be along to answer your questions. Perhaps they still will. In the mean time, I may be of some help. My references are the 1964-72 Ford Truck Parts and Accessories Manual and AMK's Guide to Ford Fasteners, 1955 - 73. The part number for the screw that holds the front parking light/turn signal bezel on is (or at least was) 379420-S. It's a Phillips Pan Head design but I can't give you more than that because I couldn't find it in the AMK book. The screws that hold the headlight doors to the grille are P/N 371828-S; they are Phillips Pan Head 5/16 x ¾ inch long. I'm having trouble figuring out the other ones you want because my picture isn't as simple as yours. If you can get hold of the '64 - '72 Ford Truck Parts and Accessories Manual, the picture with the part numbers is in the Illustrations Section 82, Radiator Grille and Related Parts. If no one else steps up with your answers, perhaps I can try again. Good luck!
The part number for the screw that holds the front parking light/turn signal bezel on is (or at least was) 379420-S. It's a Phillips Pan Head design but I can't give you more than that because I couldn't find it in the AMK book. It's not listed in the text section of the parts catalog, either.
The screws that hold the headlight doors to the grille are P/N 371828-S100; they are #8 -15 x 3/4" long. I'm having trouble figuring out the other ones you want because my picture isn't as simple as yours.
Many have suffixes after the S not shown in pics, so you have to verify the part numbers by looking under the parts they fit.
The headlamp and parking lamp pics are listed elsewhere in the parts catalog.
Thanks! You guys are the best!
I did find an almost correct bolt at the local Ace
5/16 x 3/4 flanged bolt. Just doesn't have the starter tip.
If you can share any info on getting a parts manual that would be outstanding or if anyone has had luck finding any of the other screws that would be great too!
Thanks again!
Thanks again!
Boxwood Bumper
11-09-2017 08:06 AM
jmstuede
06-12-2017 12:44 PM
Becky_is_a_66
02-18-2014 11:42 PM
BigBlueCat
10-02-2011 02:30 PM
