1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Dropping the Rear
Old 07-10-2016, 07:11 PM
Bib's Avatar
Bib
Bib is offline
Dropping the Rear
First tech post so bear with me please...
Understand I need to replace the 4"blocks with 2" blocks, got it. Question I have is it as straight forward as removing the wheel, loosen the u-bolts, push out the 4" block and slide in the 2" and re-tighten U-bolts?
2003 F350 SD 4x4...new to me. Man, this is a truck!
Thanks,
Bib
Old 07-10-2016, 09:37 PM
RainDesert's Avatar
RainDesert
RainDesert is offline
Mostly. I use 2 floor jacks. One to lift the rear of the truck, usually under the receiver, and the other jack to raise and lower each side of the axle near the u-bolts. You're only problem may be that the existing u-bolts don't have enough thread to tighten back down on the shorter blocks.
Old 07-11-2016, 05:38 AM
Bib's Avatar
Bib
Bib is offline
Excellent...thank you RD. Very much appreciated! I have seen a 2 inch block set-up for sale on E-bay that includes new u-bolts....guess that's the way I'll go.
Alecpowerstrokeward
04-30-2015 12:38 AM
acf6
26
12-27-2011 06:15 AM
jasonch
12-20-2011 01:33 AM
allingeneral
02-14-2011 07:42 PM
Uptown83
08-13-2003 01:57 AM
Quick Reply: Dropping the Rear
