Timing chain may have slipped some teeth, how can I fix this
#31
Something you need to know is the 20 inches of vacuum is not at all a sensitive enough a reading on a minor vacuum leak the Ox sensors are able to detect.
The valves would have to be pretty bad and or a major gasket leak present before you would see it's effect with a vacuum gage.
The system sensors detect an issue long before you would see it on a vacuum gage.
Good luck.
Good luck.
urif250
11-30-2002 02:23 PM
