Starter grinding on flywheel?
I bought a 1987 F350 2wd with the 7.5 liter 460. It has the T-19 4 speed manual transmission. My starter fell out at 65 mph. I had it towed home, put in a new starter from autozone, truck started but there was a horrible grinding noise. Pulled the starter and the teeth were chewed up pretty good on the starter. I pulled the flywheel cover and checked out the flywheel, there is no play, no chips or cracks that I can see. I was just going to change the flywheel but I wanna avoid all that work if its not necessary. So i've come to the conclusion my starter is grinding on the flywheel. When I go to autozone they do not give an option for a manual transmission starter, they keep telling me they are the same, which I know their not. Anyone have any suggestions? I'm thinking I just have the wrong starter, does anyone have a part number for the manual transmission starter? Thanks.
Also the starter that fell out has 9 teeth, the current starter also has 9 teeth. The chips on the starter drive are on the very edges, i'd say about 1/8" chipped off 4 of the teeth. This truck has been nothing but problems since I bought it, someone help me.
For whatever reason, RockAuto only shows one starter up to the 1991 model year. Starting with the 1992 model year, they show two different starters. I suspect places like AdvanceAuto, RockAuto, AutoZone, etc... all get their parts-interchangeability data from the same source, and that source has an error in their documentation.
For what it's worth, RockAuto shows the manual transmission starters for the 1992 Model Year as being:
PURE ENERGY: 3246SN
PS / POWER SELECT: 3246N
REMY: 97114
ACDELCO: 3371042
MOTORCRAFT: SA795RM (reman)
REMY: 25524 (reman)
DENSO: 2805307 (reman)
ACDELCO: 3361169 (reman)
PURE ENERGY: 12372 (reman)
I'd try asking for a starter for a '92 model year 460 manual, and see if that works any better.
PURE ENERGY: 3246SN
REMY: 97114
ACDELCO: 3371042
REMY: 25524 (reman)
Ford went to a PMGR starter in '92
I retrofitted one to my '87.
You need to add a trigger wire from the fender relay and move the starter cable to the 'hot' stud.
***do NOT jumper it at the starter**"
There is a difference when you switch from bendix to a solenoid throwout.
I'm going to suggest that your starter is either not indexing correctly in the engine plate or the threads for the lower bolt (into the bellhousing) are really sloppy and could use a helicoil.
Update: got the pmgr starter mounted and wired, replaced the icm and it fired right up, no grinding or anything else thought I just had the wrong starter and problem solved. Wrong soon as I put the driveshaft in and the pto driveshaft (it's got a 480 Holmes wrecker on it) I fired it up and the grinding came right back. So it sounded like the pto was stuck partially on so I unhooked the driveshaft for the pto and the cable. Tried starting it, out of gas, I must have a leak somewhere. Poured some gas in it and In the carb and it started but was still grinding. Im at a loss, I don't think the main shaft would make it grind?
