Turbo removal help
Time for the freakify mod that's if you decide to keep the stock turbo.
https://www.ford-trucks.com/forums/1...cartridge.html
Adam, do you get a commission whenever you sell someone on the mod, lol?
I strongly advise against using a cutting torch! If you have to use a cutoff wheel or saws all on the pedestal to get the turbo our of the way so you use other methods on the bolt. Torches cause truck fires. Many photos on the internet.
They are in the pedestal. How easy is it to remove the turbo without the pedestal coming off first? If that would work it would be great!
That would probably work, the only problem is that I neither have a welder nor know how to weld... Another skill that I want to learn really bad but haven't had the time/resources to make it happen yet, I have plenty of friends that know how to weld but hasn't happened yet.
Usually once they bolt head pressure is off most bolts come out easier.
I removed old exhaust manifold studs that way many times. Did that a month ago on my lawnmower blade bolt. Broke my 3/8 ratchet but came out easy after slicing the head. I don't cut off the head. Just make a slot on top of bolt head and many times a screw driver can remove the bolt after.
I have used a dremel for that many times. Just use lots of PB blaster or atf with acetone to break down the rust before grabbing it with vice grips.
#28
#29
