Moog variable rate spring question
Hey everyone. I have a 76 f250 2wd camper special w/390.
So I'm trying to install the Moog variable rate coil spring but I'm running into an issue with the upper spring mount brackets, they wont fit the new coil. Are the stock brackets supposed to fit these springs or do I need to order a special set?
The top of the new coils are shaped a bit differently then the stock ones but everything says they should be a direct fit. I know, famous last words. Just wondering if anyone has ran into this issue.
I will try to get some pictures to make this a bit more clear.
You bought the wrong springs. The cc808 are for 1/2 ton 2wd trucks and some non camper specials. I made the same mistake last year. These are the correct springs for a camper special
https://www.stockwiseauto.com/acdelc...D=pwf616731g1&
F250DUDE66
02-02-2016 03:28 AM
Seabeetough
03-25-2003 02:03 PM
