Rebuild transmission or simple fix
If reverse goes in just fine and holding it can prevent it from popping out you need to replace reverse gear, syncro hub, syncro slider and the blocker ring (most times called the "syncro"). You'll also want to check the shift forks while your in there as they wear out easily too.
Ford has released a tsb for reverse gear "eating" itself and that's more then likely what has happened.
f350rebel7788
24
11-19-2021 09:43 PM
mech1
01-20-2011 04:56 AM
