240 to 300
240 to 300
Question: I have a 240 engine; is making a 300 simply using a 300 crank and associated parts? Are there any mods needed, like clearance the block?
I believe the answer is yes, that putting the 300 crank in is no problem, but figured to ask the esteemed experts here.
And yes, I know there are more combinations of rods and pistons that can be put in, but don't mean to get into all that. I bought this engine cheap mainly for the head, but got to thinking that maybe I could just go ahead and make it a full buildup while I'm wrenching.
TIA!
TIA!
TIA!
TIA!
Swap in a 300 crank, connecting rods and pistons. Both blocks have the same cylinder bores so it's a direct swap. Just don't mix rods and pistons between the two ( use 300 rods & pistons with 300 crank ) and you are good to go.
