Rear End Allignment Question
Old 07-22-2016, 10:49 AM
spooktn's Avatar
spooktn
spooktn is offline
Temporarily Deactivated
Ok took my truck to a local shop that has frame straightning equipment and they did a free inspection and did not see anything wrong with the frame or leafs or bushings and said everything looked to be as it should be,,,, just eyeballing it of course,,, and said for $80.00 they would put it on frame machine and do a full test ,,,, so now I think it is a bent axel housing for sure,,, anyone want to add their 2 cents here please ,,,,, could use a little more advice here,,, anyone ????????????????
Old 07-23-2016, 09:40 AM
shultzaberger's Avatar
shultzaberger
shultzaberger is offline
I guess you could put an angle finder on each of the axle tubes to see if one is bent up more in relation to the diff housing. I don't know if the axle tubes are press fit or welded. If they are press fit I guess it could move with a really bad impact.
ke7gpu
1999 to 2016 Super Duty
15
05-23-2018 10:44 PM
truckin99
Offroad & 4x4
13
02-25-2006 02:35 PM
1badsupercab
01-29-2004 07:04 PM
Steve
03-04-2000 02:03 PM
Quick Reply: Rear End Allignment Question
