31,500 towing numbers release
They didn't state which Super Duty but I'd bet it's the 450 which is capable of 31,500 lbs of towing.
Follow this link for information. Best in class capabilities
I know that 31,500# is huge and no one in their right mind would tow up to the limit with an F450... but all of this hype, bigger frame, bigger brakes, bigger suspension... and we get no GVWR increase and a whopping 0.96% increase in towing capacity? What is the benefit of all of these changes other than marketing hype?
This one says OVER 31,500 lbs. That could be 38k or it could be 31,501.
Now you're starting to understand how sales and marketing work.
Also they can't increase GVWR because of class limits. A class 3 truck stops at 14,000#. 14,001# is a class 4 truck and is now a medium duty therefore ford can't market it as light duty truck to compete with the other brands. It doesn't matter if a F350 can tow 80,000lbs it will still have a GVWR of 14,000# to be considered a light duty.
Also don't expect any huge jumps. The new SD will handle probably around 35K easy but they will trump the Ram by 500# at a time. This is all about marketing, why beat someone by 5,000 and your truck never improves for 5 years? Or you can increase it by 500-1000# every year and every year you can sell a "bigger, better improved, more capable" and entice people to but a new truck every 2-3 years.
How can the truck ensure it can slow down quickly enough with that much weight? What if the user set the trailer brake gain down at 2.5?
Depends on what you are doing and in what states. For commercial use you will need a CDL in most states. For AG or RV use you will not need one in most states.
I don't think adaptive cruise is cool when you're towing that much. Because of the ease in which these modern, ultra-powerful HD pickups move a load, people forget just how much weight they have behind them and how much more responsibility that brings. Adaptive cruise lets you pay that much less attention. Look how well that worked out in the Tesla autopilot crashes recently...and they weren't towing anything. Let the truck have adaptive cruise control, but with anything plugged into the trailer socket, the feature is disabled.
