Rear disk conversation? Rear axles?
Looking for some information regarding my 94 f350 turbo 4x4, I need to know what type of axles I have in the rear?
The bracket is stamped S132-G 4.10
I am going to do the disk convertion, because I need new brakes on my f350 and it so happens that I need to replace everything, shoes, drums, hardware, and emergency brake kit as well. So the cost was about 275.
Might as well do the rear disk.
My question is since so many brackets are available and even full kits what would be the best option,
1. Lug nuts kit
2. Great Lakes off road
3. Buy brackets and make my own
1. Lug nuts kit
Received 3,106 Likes
on
Thank you for confirming. I just really hate drums in the back they always fail, so I think the little money upfront will help with easier brakes changes.
How do drums always fail? The only thing I've noticed is having to occasionally check the adjusters(because auto adjusters don't).
On the other hand, I've had front disc calipers stick more than once, especially on a truck that isn't used frequently.
And sure, perhaps drum brakes need more pressure for the same stopping force, but that's why Hydroboost exists. Get yourself a hydroboost conversion, and you'll be able to lock the wheels at will, /without/ having to pull on the steering wheel and throw all your weight on the pedal.
That's what I did on my main towing truck, and it's so much better than the (admittedly probably worn out) vacuum booster system that it replaced that I haven't needed to worry about braking as much.
i just completed a disc conversion on my 87. from lugnut 4x4
when i tore my drums apart, alot of broken springs.
so disc it was....
i like them, for the ease of repairs and simplicity.
your stock e-brake cables will not work, you will need to get aftermarket cables.
you will need the f superduty master as well.
i like them. stops on a dime, we will see if i feel a difference when towing.
so disc it was....
I put SD axles in my 92. Discs all the way around, stock master / booster. The difference is just insane. Still have my nice pedal feel, good brake feedback, and just crazy stopping power. Actually almost scared to push on em too hard loaded, for fear of breaking a spring hanger or spring or something lol.
shorerider16,
I used to have a 2001 F-350 dually with a Dana 80 that had rear disc brakes. When I had my camper or a heavy trailer, the parking brake was usually questionable. I tried to park on flat ground whenever possible. It wouldn't hold much. The shoes were dry and adjusted properly. They were just small.
on
Weld On Rear Disc Conversion Brackets - 3.5 dia. tube [1235] : TMR Customs, Custom Fabrication Components for Offroad Vehicles
Find a better supplier, I bought all the pieces to do the rear for less than 500$ everything from the brackets to hoses. And that's in Canada I have yet to install it had the parts almost 5 years. I used E350 rotors that were still the old pattern they were 90$ each at the time and 3/4 ton 73-87 4x4 chevy front calipers 50 each brand new not reman, pads were 40$ and hoses to match them they were 20$ each, and brackets from tmr custom's 65$. But you get no park brake, I plan on figuring out a drive line brake for that pickup. Even a full rebuild on drums on the back is usually close to 200 to 250 depending on which kit and quality of parts. Biggest issue is usually either they don't adjust and they back off sometimes.
I typically shop at Lordco, I buy off a good account and they are typically right in line with everyone else in town. With the dollar so far in the hole it doesn't really pay to shop online out of the states anymore. I see you're in BC as well, where do you typically get your stuff?
I would definitely want a parking brake, my current truck doesn't have one it is incredibly inconvenient at times, so when I build my 93 that will be a must have item. I imagine I could piece together a kit for less than 500 as well, but not with a parking brake. Just the park brake calipers from Lugnut with pads is over 425 Canadian. The Lugnut kit with parking brake and all the components is over 800 Canadian, plus taxes and duty, a lot of cash when I can completely overhaul a set of drums for a few hundred.
I was intrigued initially but it doesn't really seem worthwhile. As much as I'm not a big fan of drum brakes I've never had an instance where they didn't get the job done.
on
