Converting to Carb from EFI
Alright guys I need help converting a late 90's block 302 to carburation. I'm going mechanical fuel pump which means I'll have to use an eccentric. From what I understand the stock timing set will not allow me to put an eccentric on it. Will a stock replacement for any mechanical fuel pump 302 block fit on it? Another thing is those dowel pins. When I took the eccentric off of my 74 351w block the camshaft dowel did not penetrate the eccentric. It had a lip that went in the timing set so I'm just going to reuse it if I can.
chcknugget
07-26-2012 10:45 PM
Onus
12-25-2011 10:27 PM
sko_ford
10-23-2011 01:33 AM
fishin1976
49
09-22-2003 08:53 PM
