2013 Coyote 5.0 Spark Plug Service (HELP) things went bad !!
Ok guys, I need advice on what to do now
Went out to change the plugs on my 2013 5.0 (50k miles) & while removing the very 1st 8mm bolt, which holds the Coil in, SNAP.... I sprayed all of them with PB-Blaster, tapped w/a small hammer (to shock bolt) & since that had to be a fluke, I attempted to remove a 2nd one, SNAP
There is nearly 1/4 inch of the broken stud exposed (after pulling coil out) so I attempt to remove it with vise-grips (did not work) then I call local Auto Parts Stores to look for a extractor of some kind...Nothing that small
I need some kind of extractor to fit the appx 1/8 inch diameter stud or a great idea.
I can't be the 1st person who's encountered this, suggestions
Very surprised nobody has responded to this Thread
Either people aren't reading/responding to "help" Threads in the Gas'r community OR there aren't as many issues with Gas engines, as we had in our Diesel community & so nobody really knew what to do.
I am going to hope its the later & post how I finally ended up fixing it, so the next guy this happens to, has a possible solution.
After a few days spraying PB Blaster on all the Bolt's, I was hoping the remaining 6 could be removed without breaking & the 2 I broke could be extracted by vise-grips.... Well it didn't exactly happen that way
I was able to extract 1 of the broken stud's with vise-grips, but not the other & I broke another of the remaining 6 off, which I couldn't get out either
So in a nutshell, I was able to remove 5 without breaking, extract 1 with vise-grips & the other 2, I broke out the welder.....lol
* See next 3 post's for my solution
First, I tried to weld a nut to the broken stud's, in order to get a good bite to turn them out & I figured the heat would help to remove.
I did that by placing a pair of needle-nose vise-grips on the nut I placed over the stud, then attached the ground clamp to vise-grips. A real quick weld from my wire feed welder & I thought I was smart, until the entire stud & vise-grips just fell out of the stupid plastic valve cover
That actually turned out to be a good thing & I removed the other broken stud the same way. What I did with the hole was screw a brass furniture type insert in there (picked up at Lowes) after heating it real quick w/a small torch (to aid in cutting threads). The insert uses a 1/4x20 thread instead of the metric 5mm OE uses, so I had to buy 2 1/4x20 bolt's of the same length w/washer'd heads also.
* Pic shows the insert p/n & the insert installed in valve-cover.
Lastly, a pic showing the brass insert I used (un-installed) so u have a visual & the completed repair.
In this pic the coil on left is still held in w/OE 5mm & the coil on the right, is held in w/my brass insert using a 1/4x20.
IMO, the difference is barely noticeable & I didn't have to remove the valve-cover g
Way to think on your feet sir, thanks for posting.
Here's a must have for any tool box: Extractor Sets - Screw & Bolt Extractors - Tools - IRWIN TOOLS
sammie0126
03-26-2022 07:13 PM
cosmofennema
07-26-2019 07:39 AM
