Tire PSI for towing ?
Hi guys, tomorrow I will be towing a dump wagon filled with #2 stone for my neighbor...
What PSI would you suggest as a starting point for the tires ? Currently for street use (non towing) I run mid 30's I know that won't be enough just not sure how high to go..
Tire size and wheels are in my sig if it mattters........He didn't say how big the trailer was that he rented....One thing is for sure I will not let the pit over load it..
Thanks, Mike
Thanks, Mike
I wasn't sure if that applied to 35x12.5 tires or not ?
Looks like the Nitto site says 65psi max, I'll try 60 as a starting point and see how she does..
Nope, it certainly does not. Factory door sticker is only for the factory tire size. Disregard for aftermarket sizes.
See attached, I pulled it from a load inflation chart published by Toyo tires. These are TRA standards, so they apply to all brands.
At 40 PSI your tires would support 2,625 lbs each, or 5,250 lbs per axle. Your front is safely under that with the gas engine, and the rear should be around 3,100 lbs empty. So unless you're loading more than 2,000 lbs on the rear axle I'd stick with 40 PSI. Adjust as needed, 50 PSI would support 6,000 lbs on the rear axle.
Good catch on the different tire. Didn't even cross my mind as I always run similar tires to stock, but yes; you shouldn't go over 65 PSI in those tires according to the manufacturer. 60 would be fine for a lot of payload. Usually, you run out of squat on a 250 before you're in any real danger of doing tire damage running those kinds of pressure anyways.
When I saw the trailer I thought, "we needed my truck for this" ?
As it turned out his F150 didn't have electric trailer brakes or something so the rental company wouldn't let him have the trailer......we did need my truck after all
