Truck won't start
Old 07-04-2016, 11:16 AM
LSJUNIPER's Avatar
LSJUNIPER
LSJUNIPER is offline
Truck won't start
It's a 56 truck with a 1977 LTD motor. Removed the fuel tank and cleaned it out. Replaced all of the fuel lines. Replaced the fuel pump and the inline fuel filter. Still gas is not getting to the filter or the carb...if I put gas in the carb it starts right up and runs for a few seconds....?????? Any suggestions.... ????????
Old 07-04-2016, 11:18 AM
Stephen67's Avatar
Stephen67
Stephen67 is offline
Is the carb set to run too lean?
Old 07-04-2016, 11:33 AM
LSJUNIPER's Avatar
LSJUNIPER
I think the carb is good...but fuel doesn't seem to be getting to the carb...
Old 07-04-2016, 11:44 AM
toby tough's Avatar
toby tough
toby tough is offline
Is there fuel to the pump? Do you have a vac. pump to hook to the fuel line before the pump? Maybe pull some fuel through, prime the line so to speak. How about the pick up in the tank?
Old 07-04-2016, 12:33 PM
1952 Ford's Avatar
1952 Ford
1952 Ford is offline
Unhook the line that feeds into the carburetor and crank it just for a few seconds and see if fuel come out. If it does then there's something plugged up in your bowl. Have you rebuilt the carburetor? It could be getting into the carb just not past the bowl. If fuel doesn't come out the line it is probably a pump issue.
Old 07-04-2016, 02:30 PM
LSJUNIPER's Avatar
LSJUNIPER
Thanks all....took the fuel line off of the pump and blew air I to the tank...it is now running.
Old 07-04-2016, 06:57 PM
Mixer man's Avatar
Mixer man
Mixer man is offline
I'll wager that whatever was blocking the suction in the tank that you blew out will eventually find it's way back to the suction tube. I'd look into this at your earliest convenience.
Mikey G
08-12-2016 10:00 PM
jawroper
05-26-2015 04:29 PM
shawnyboy
10-13-2009 06:05 PM
T2Load
19
07-29-2007 06:20 PM
Swampdonkey09
03-06-2004 07:54 AM
Quick Reply: Truck won't start
