Frozen rear drums - Tips/Help
Old 07-04-2016, 08:55 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
Just maul the drums apart already ...
Old 07-05-2016, 08:29 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,078 Likes on 2,148 Posts
put never seize on the axle flange where the drum will touch, and a dab on each wheel stud. this will make it much easier to remove the wheels and drums the next time you have to do it in 15 years.
Old 07-05-2016, 09:45 AM
Festus Hagen's Avatar
Festus Hagen
Festus Hagen is offline
Methanoholic
I've never had much luck with just a dab of Never Seize, I find that just a dab doesn't spread and cover all ... I find completely coating (like painting) with a very thin layer works best!
-Enjoy
fh : )_~
Old 07-05-2016, 09:56 AM
tjc transport
i ain't rite
that is what i call a dab.
cover it so no bare metal is showing.
Old 07-05-2016, 10:01 AM
Festus Hagen
Methanoholic
Awesome ...
I see many folks just putting a dab on the end of the bolts and that does not work ... So I like to make it clear.
-Enjoy
fh : )_~
Old 12-06-2016, 11:40 AM
Oldforddy's Avatar
Oldforddy
Oldforddy is offline
My left rear wheel on my 1988 F250 won't turn unless I drive the truck. I set the emergency brake last week and drove the truck until I noticed the smell of brake lining and the wheel began to smoke.
I've turned the adjustment wheel up many turns (it won't turn down). I can see a loose spring or part of a spring through the adjustment hole.
My plan is to proceed as follows until the drum is free or turns.
1. Cut the ER cable at back plate
2. Drill out the pins that hold the brake shoes
3. Unbolt the wheel cylinder and brake line
Once the wheel turns, I'll address removing the drum with PB blaster, heat, tapping, etc.
Thanks for comments and or further guidance/advice.
Oldforddy
Old 12-06-2016, 02:20 PM
joey2fords's Avatar
joey2fords
joey2fords is offline
interesting approach. if i remember correctly, the brake return springs pass behind the axle flange, so i am not sure the whole works will come off, as you are planning, but i am curious to see how it turns out. good luck.
Old 12-06-2016, 03:05 PM
88_F0RD's Avatar
88_F0RD
88_F0RD is offline
haha
Originally Posted by '89F2urd
Bigger hammer
like a sledge hammer!
Old 12-06-2016, 09:10 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
I ended up removing the axle from the truck and using a sledge. lots and lots of hammering to get damn things off. hands down the worst brake job I've ever gotten stuck working on
I did cut the e-brake cable since they were frozen. sadly the whole mechanism had frozen interal to the drum so nothing worked
Old 12-07-2016, 05:58 AM
Cleanseeker's Avatar
Cleanseeker
Cleanseeker is offline
Originally Posted by subford
Most of the time you can just take a pneumatic hammer with a straight blunt punch and hammer between each lug and the drums will come right off before you get all the way around.
That has worked for others on here with the same problem.
I would be one of them that this worked for.
If you don't have air tools, try a metal rod and a hammer.
Hope the input helps.
John
Old 02-03-2017, 09:41 AM
Oldforddy's Avatar
Oldforddy
It's been two months, but I did get the drum off. The sledge broke the drum loose, but the broken spring jammed the adjuster. Once I drilled out the pins from the back, the drum gave. After that, I was able to work it off.
Thanks,
Oldforddy
Old 02-03-2017, 10:02 AM
madpogue's Avatar
madpogue
madpogue is offline
This ^^^^^^ is exactly why we rotate our own tires, or do the winter/summer tire swap ourselves. What would take 10 minutes in a shop takes 2-3 hours for us, because we pull both drums and inspect everything, give the non-friction moving bits a light coat of Fluid Film, make sure there's no ridge/lip on the drum from pad wear, etc. And remove and lube the caliper pins up front, etc. Learned the hard way, had a couple drums rust-freeze to the hub and had to "ring the bell" with a sledge hammer.
fridgeddiesel
10-18-2013 11:14 AM
75highboy390
11-01-2011 10:00 PM
HD74
10-13-2009 04:21 PM
MercuryM100
04-01-2004 11:58 PM
kasparsport
08-31-2003 08:16 AM
Quick Reply: Frozen rear drums - Tips/Help
