Diffrent Oil cooler solutions
I did pull the coolant exit port cover off today and Back flushed with water and a mix of compressed air
I haven't drove to far but did get it hot and Oil would go up but also come down fairly rapid like it should
I keep you updated current cooler is only 30 days old
That hose is a good idea for back flush BUT it needs a way to just hook a hose to and give if a Good water flow flush
The tee fitting would need one side plugged
I wish! But I installed my kit several years ago and have had zero issues with it, I think to be a good salesman you have to believe in the product so I could sell sleep number beds, BPD kits, and weber grills
#29
That was part of my thinking and using the bulletproof diesel oil cooler relocation kit I could splice in a high flow coolant filter and it could be easily back flushed
Plus it's easy to change
But the air to oil cooler is pretty close to the same money IIRC
I'm just concerned the oil may stay little cool in winter here iirc they regulate at 180* EOT THERMOSTATE that seams a touch cool
I DONT Want to increase injector sticktion by running to cool EOT my inject need the spools cleaned
Sticky ion will always be an issue but was hoping to put a oil cleaning centrifuge in but I need the truck to not breakdown for a min to afford it there around $500-600 for an oil cleaning centrifuge if there advertisment was correct it did an awesome job at cleaning The centrifuge would take black oil and clean it and get close to the original brown colored oil within like 1000 miles
#30
So instead of an oil temp "delta", your entire engine just runs hotter!!
