Will normal headers work on 460 swap
And they're called "swap" headers because the 460 was never offered in 4WD F100s or F150s.
I know you're on a budget but when dealing with non-standard drivetrain configurations there is likely some issue that will reveal itself unless thorough research is done at the outset.
Another option is Sanderson 3/4-length headers (PN FF461) but they're relatively pricey. However, they can provide the greatest flexibility in avoiding clearance issues as indicated above with L&L. In the end, what is it worth to ya?........ https://www.sandersonheaders.com/hea..._block_429-460
On the flip side, buy a welder and modify at set of low-buck headers .. the driver's side will need to altered to move inboard to avoid the front driveshaft. Pie-cut, bend, and re-weld... and you get to keep the welder.
