Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2001 Escape 6 cyl Won't Start
Old 07-02-2016, 03:33 PM
no5outof6's Avatar
no5outof6
no5outof6 is offline
Question 2001 Escape 6 cyl Won't Start
About a block and a half from the house, it died while driving. Had heard some noise coming from rear drivers side maybe 20 minutes prior, and assumed it was the fuel pump. Another gentleman who helped push me home, guessed the same thing after banging on it while trying to restart it.
So, I have put a new fuel pump, filter, and relay. Will crank, but not turn over.
Next step was carburetor fluid in throttle while starting, still wouldn't turn over.
Help please!
Old 07-02-2016, 09:46 PM
scott91370's Avatar
scott91370
scott91370 is offline
No engine light/codes?
Have you tried to measure voltage at the fuel pump?
Old 07-02-2016, 10:30 PM
no5outof6's Avatar
no5outof6
No engine light/codes.
No meter to test voltage at fuel pump.
Old 07-03-2016, 07:09 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Then you might as well use a crystal ball.
Get the right tool and do the diagnostic work.
Old 07-05-2016, 11:25 AM
got2bjoester's Avatar
got2bjoester
got2bjoester is offline
For S and G's, check the inertia switch located behind the passengers side kick panel.
There should be access without removing the cover.
As pointed out, you really need proper tools to accurately and properly diagnose the issue.
Old 07-05-2016, 02:47 PM
projectSHO89
Since it wouldn't fire with "carburetor fluid in throttle while starting", it's not a fuel delivery issue, it's probably a spark issue.
idlewild
1983 - 2012 Ranger & B-Series
08-10-2015 03:10 PM
grader61
1999 to 2016 Super Duty
01-25-2009 12:24 AM
black95tt
17
10-02-2007 12:10 PM
yh731801
04-16-2007 04:54 PM
Saurian
09-08-2004 10:26 PM
Quick Reply: 2001 Escape 6 cyl Won't Start
