I think I did a bad thing.
Old 07-02-2016, 01:13 PM
thedopefishlives's Avatar
thedopefishlives
thedopefishlives is offline
I'm working on repairing my '79 400 after an engine fire melted a whole bunch of things in the front of the engine. I decided this was the time to swap distributors, since I had a known distributor issue. I cleaned as best I could around the base of the distributor before pulling it, but despite my best efforts, a small pile of dirt and fire extinguisher residue fell into the hole when I lifted the distributor clear. How screwed am I? Is there anything I can do to clean up this mess without pulling the engine and disassembling it?
Old 07-02-2016, 05:44 PM
Kruse's Avatar
Kruse
Kruse is offline
"..a small pile of dirt and fire extinguisher residue fell into the hole..."
You said small amount, so I'd just take a shop vac with a small suction tube, suck out what you can, assemble everything and run it. If it makes you feel better, install some new oil and a new oil filter ahead of time and possibly change your oil somewhat sooner than you normally do after you get it running.
Old 07-03-2016, 07:16 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
I agree - clean as best you can. But, I would wash the stuff you can't get down into the sump with a squirt can of engine oil so it won't get onto the cam gear or timing chain. Then, after starting it and letting the engine run for a bit to ensure the stuff does get washed down into the sump, drain and refill the oil and replace the filter.
DTexUS
35
04-24-2018 12:06 PM
MattMac
05-23-2017 12:24 PM
bigmike09
Oil & Lubrication
16
09-17-2010 04:38 AM
ford truck oldboy460
02-06-2009 07:17 PM
Repsher
07-10-2005 12:33 AM
Quick Reply: I think I did a bad thing.
