A4OD on a 72 302
A4OD on a 72 302
Hello, I am building a 1931 ford truck and using a 1972 302 I have a a4od not sure what year. It all came with the truck when i bought it. the transmission is bolted to the motor right the flex plate is not on the motor. My question is do i need a certain year flex plate and what year starter will work. If you need more information I will give what ever you need. I am excited to be on this forum and am really grateful for any help that you all will give me. Thank you Sonny.
ID trans via this here link and counting the pan bolts. AOD most likely:
https://www.ford-trucks.com/user_gal...d=169485&.jpg=
Note the AOD requires a Throttle Valve (TV) cable or link and is very picky about adjustments. Transmission failure is guaranteed without proper adjustment.
Flex plate should be 28 oz. imbalance 164 tooth, if I read this here correctly:
Ford Flywheels and Flexplates
Yes It is a AOD and i have already looked up the cable. My dad had a transmission shop a long time ago, about 25 years ago. I have built some transmissions a long time ago. Just don't remember munch about this one AOD. We raced dirt late model fords 351 w with Cleveland heads. years ago just rusty on knowing what will work. Thank you very much for you help.
jeffinct
05-07-2018 09:17 AM
Fishdood 1
11-14-2002 08:31 AM
