How to release fuel injection pressure to swap filter
How do I release the fuel pressure in the system before I take the fuel lines apart to replace the filter or am I just supposed to get it all over me and the ground? Is there a button to push, or an epithet to hurl at it that works wonders ?
You did not tell us what you have for a truck but I will assume it is oin the late 1980's early 21990's period. There is a schrader vaave on the right hand front fuel =rail that has a cap on it. remove the cap and push the needle valve while making sure the engine is cold and you stand back with the truck off.
If the truck hasn't been driven in a couple weeks there should be no pressure on the system anyway.
But to answer your question the way to do it is to either pull the fuel pump relay out or trip the fuel shut-off switch and try to start the engine and crank for a few second if does not start.
Yea, I just remove the clips if applicable and pull the line(s). Sometime I have a shop towel in my hand to soak up the fuel
You say that, but I guy I knew did that same thing and ended up taking it straight to the eyeballs because he didn't relieve the pressure first.
Thanks all !
Good advice all, too.
But......
I relieved the pressure in the system - not much, of course, since it hadn't run in a couple weeks. Got a dribble or two out of the valve.
My plan when I pulled the hose from the tank was to catch it quick before the tank filled my shirt with gas, then I noticed the gas running down my arm was coming from the other side of the old filter. That made sense then since there would still be gas in that part of the system.
After the filter swap was made I found it went much easier if I didn't put the clips in backwards.
Technology ! It's great aint it ? (all my experience is in carburetors - had my '68 Ranchero in the 4th parade today)
But......
19fifty4
07-10-2010 01:54 PM
HD61cuin
01-10-2003 08:27 PM
