Turning front wheels by hand while jacked up
Received 3,106 Likes
on
Please note that this is with the front wheels off the ground, in P, not running and in 2wd.
Also, as stated earlier when I put it in 4wd I hear the typical clunk and you can clearly tell it is then locked in by both sound and feel.
it has been like this for months....probably longer.
probably why I get 13 miles to a gallon.
I just can't figure out what it would be.
any value in changing on the two solenoids on the fire wall or is that just wasting money?
on
This generation of F-150 w/4WD has a dog-clutch on one axle shaft inside the front axle assembly. When it is disconnected, one axle spins free (still connected 100% permanently to its wheel), the other wheel, when spun by hand or road contact, turns its axle shaft, which in turn spins the spiders in the diff, so there will be more drag and more mass effect. You can see which axle half gets the disconnect by looking where the vac motor and its link goes to. I think its the passenger side...
For the next-design 2004 (not 2004 Heritage, which is the 2003 design), they went back to dual disconnects to reduce overall drag when in 2WD. Went full circle, probably due to gas prices, and EPA corporate full economy.
on
Or is this normal?
Thx
Looks like I should jack one side at a time and try!!!!!?
From F150.net
Regarding the binding feeling when spinning the passenger side wheel when raised. I don’t believe this is an issue. The differential is not centered, the passenger side axle/CV is longer. I had raised the truck under the frame cross member, both wheels in the air. The driver side has no binding, the passenger side does. I believe with the truck raised this way, the CV joints on the right are fully extended at a more severe angle. This is why it binds when spun. When I jack the truck under the normal jack point the passenger side does not bind when spun
From F150.net
#28
If I were conducting the experiment, I would put jacks or jackstands under both lower control arms at the same time, such that the front wheels just clear the ground, with wheels pointed straight ahead. This will put the front suspension at regular ride height, so both CV half-shafts will be running straight inline while you spin the wheels by hand. This will take any CV joint angular losses out of the picture. Just like working on a FWD car front end.
#29
#30
OK, how do you post a video?
