Proper Reamer for Pitman arm and DAN60 swap
What Dana 60 are you using that does not use the standard 1.5" per foot taper that ford & Chevy TRE's use ?
the Dana 50 in your excursion uses the same TRE's as a super duty Dana 60
Here is a reamer since that is what you asked for, I am just not sure why you need it.
Reamer for GM 1 Ton TRE's - RuffStuff Specialties
Bryanblaylock
09-30-2015 07:00 PM
GTBksRule
04-02-2005 05:46 AM
