1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2006 F250 Auto trans will not go into overdrive
Old 06-30-2016, 12:18 AM
jst3751's Avatar
jst3751
jst3751 is offline
Trailering
Exclamation 2006 F250 Auto trans will not go into overdrive
I have a 2006 F250 with the 6.0 PowerStroke and automatic transmission. I just purchased this truck at an auction about a month ago.
Today I notice the transmission is not shifting into overdrive. No warning lights. If I press the tow/haul button in no change but the tow/haul light does come on. If I press it again (to turn it off) the tow/haul light goes out but still the transmission will not shift into overdrive.
This leaves me at about 2000 RPM at 68 MPH. I just had a Ford dealer perform Transmission service last week. (20,000 miles after the last recorded service.)
I am already not happy with the service I received at the dealer so I am really hesitant to take it back to them if it is something not related to the transmission service they performed.
Any one have any idea of what the problem could be?
Old 06-30-2016, 04:54 AM
redford's Avatar
redford
redford is online now
Received 1,564 Likes on 912 Posts
2000 RPM at 68 MPH sounds like it's in 5th gear to me, assuming you have 3.73 differential gears.
Keep in mind, T/H mode does not lock out O/D, it changes the shift map below 60 MPH.
Old 06-30-2016, 07:34 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,576 Likes on 1,054 Posts
I don't see a problem. At that RPM and speed the transmission IS in overdrive.
From a rest count the upshifts.
Old 06-30-2016, 09:44 AM
r2millers's Avatar
r2millers
r2millers is offline
Perfectly normal to me. I bet you had a 4r100 tranny in the past and believe the tow/haul button works the same as the O/D button from earlier years. Just not the same.
Old 07-01-2016, 04:26 AM
jst3751's Avatar
jst3751
jst3751 is offline
Trailering
Thanks everyone. A friend of mine told me he is usually at 1700 RPM at 68 MPH with his 2008 F250 diesel.
Old 07-06-2016, 11:56 AM
r2millers's Avatar
r2millers
Just can't compare those numbers, 6.0 vs 6.4.
Desperate Dan
12-05-2020 07:39 AM
Money-Pit
01-06-2013 11:51 AM
lawmac2005
12-09-2010 05:56 PM
crownvic
02-10-2009 05:55 PM
RagdollRacer
Toy Hauler Towing; Fifth Wheel & Bumper Pull
15
01-30-2008 09:40 PM
Quick Reply: 2006 F250 Auto trans will not go into overdrive
