Clutch\brake pedal
Clutch\brake pedal
I did the first drive with my truck today. About 20 miles. Only problem i see is that when i press the clutch pedal the brake pedal slightly applys. The brake pedals moves down about an inch. Im thinking that maybe the pedal assembly needs a cleaning and lube but i done know yet. Just wanted to ask what this might be. Thanks!
Could the problem be the infamous firewall crack/flex? Sounds bad, but very common and easily fixed with a special bracket. Would that let the entire pedal assembly move relative to the brake master cylinder?
I'd suggest having a helper cycle the clutch pedal while you watch the engine side of the firewall.
According to your "About Me" profile, you have a 1985 F250 that has a hydraulic clutch. But, 1980/82's did not have it, neither did 1983's unless they had 6.9L diesel or 460.
Beginning in 1984, all F150/350 & Bronco's have a hydraulic clutch.
3 pics of clutch/brake pedals.
Dave - - - -
Rust can build between the shaft & bushing or bushing and pedals or both and close up the gap or pressing/expanding the bushings and keep them from moving freely.
Had this happen on my AMC Javelin of the brake booster pivot bracket. Rust was so bad you could not move the pivot. It chewed up the bushings trying to get it apart. Had to make new bushings, that was fun, as no one sells replacements.
Dave ----
Dave ----
SonofaFord
09-30-2011 06:51 PM
Daytona F1
01-01-2011 05:17 PM
