Low Fuel Pressure, did I hurt my injectors?
#31
#32
Actually, I've seen that much bounce with my gauge. You're seeing a 40 - 80 PSI bounce, which is an average of 60 PSI. I'd call that good. If you add a BB now, it might raise your fuel pressure too high.
If I saw this reading on my truck, I'd be happy with the repairs made and call it good. No further repair needed.
#39
#40
#42
Depends on how many miles you drive annually. It's easy enough to check. If it hasn't been replaced in a while, it's probably due.
There is also a screen in the filter housing/FPR assembly that should be cleaned, too. It is not a removable/replaceable item. Just use a cotton swap, with the cotton end removed/broken off, and gently wipe the screen clean. The residue removed is from the o-ring. Amount of residue will give you an idea if your o-ring needs replacing soon.
I prefer to clean this screen and replace the o-ring, if needed, before adjusting fuel pressure with a BB. That's just me, but if I'm adjusting fuel pressure back into specification, I'd like to be certain my efforts will have a positive effect on performance. This screen can become clogged enough to affect fuel flow, which can affect performance.
#44
#45
DieselTechRon, on YouTube, (
), is a good resource. In this video, he's using a tool I can't afford. He uses a gauge around 3:45 in the video.
Another decent one is Trey Spooner. His video might show up on the right side of the screen. It did for me.
I found these by searching for "check fuel pressure on ford powerstroke" on YouTube.
