Electrical issue - Ford Truck Enthusiasts Forums
Electrical issue
Old 06-29-2016, 06:48 PM
blue76 blue76 is offline
blue76 is starting off with a positive reputation.
Electrical issue
So,on my 70 f250 I disconnected the battery, both terminals. Took out the battery to clean the tray. Put battery back in tried to start and all got was a click from the starter and lost all power, no lights, nothing, completely dead. Put battery on charger and the charger says it was charged. Figured maybe I have a bad battery. Took it in to get tested, test said it was ok. I got a new on anyway. Put it in. Starts great no issues. A day later go to start. Same issue. Starter tries to start, but not enough power and no lights again. Completely dead. I checked the ground on the block, cleaned it . No help. Checked connections. Put new battery on charger even though the charger says its charged. Not sure what I'm missing.
Any ideas?
Old 06-29-2016, 06:59 PM
CougarJohn CougarJohn is online now
CougarJohn has a good reputation on FTE.CougarJohn has a good reputation on FTE.CougarJohn has a good reputation on FTE.
Blue, if you have power into the vehicle and everything works but the starter, you should start by cleaning up the terminals from the solenoid to the starter. The solenoid is the box on the fender where the battery cable connects.
If you do that and have no results come on back in and tell us your symptoms.
Old 06-29-2016, 07:08 PM
I'll try that, but after I try to start I have no power at all. Not even enough for the domelight.
Old 06-29-2016, 07:19 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Clean and firmly secure both ends of the battery cables (positive and negative). Also clean the battery posts to expose new metal.
Second, make sure the ground strap between the engine and the firewall is also clean and secure... a loose or missing ground between the cab and the engine creates all sorts of weird symptoms. Ask me how I know! .. One time my electric fuel pump cycled when I turned on the headlights!! After reconnecting that ground strap everything went back to "normal".
Old 06-30-2016, 01:33 AM
Talltruck's Avatar
Talltruck Talltruck is offline
Talltruck is starting off with a positive reputation.
Do you have the bolt on style battery ends?
Old 06-30-2016, 04:33 AM
GaryKip's Avatar
GaryKip GaryKip is offline
GaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to behold
IF, after doing all the above you still have no power, check/replace the starter solenoid.
Old 06-30-2016, 09:25 AM
orich's Avatar
orich orich is offline
orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.
These old classic many people don't ever think of changing out the 40+ yr old battery cables. The old cables over time depending on your climate can corrode inside the insulation and build up of a green corrosions of resistances that cuts down the flow of voltage.
Once your cables have been removed and reattached is the main cause of a poor connections at the battery itself. Clean/ but best to replace all the three large battery cables to insure a good voltage flow of your vehicle.
Rear engine grounding strap is important needing to be good also.
The starter solenoid mounting screws should be tight also as they also secures a good grounding path.
And any of these could be your problem.
Orich
Old 06-30-2016, 09:34 AM
Turbo Dog's Avatar
Turbo Dog Turbo Dog is offline
Turbo Dog has a good reputation on FTE.Turbo Dog has a good reputation on FTE.Turbo Dog has a good reputation on FTE.
I agree and you can test your cable by putting a meter across them when the circuit is active. Put one end of the meter on the cable at the battery, then the other end of the meter on the other end of the cable. The meter will read the amount of voltage dropped across the cable when the circuit is active. It should be almost zero.
Old 07-01-2016, 04:23 PM
Yup, it was the positive battery cable. Thanks guys!
Old 07-01-2016, 04:35 PM
Double-plus-good call, Orich.
Semper Fi
Old 07-01-2016, 08:23 PM
orich's Avatar
Like dirty old men & dirty old battery cables all can cause problems.
Thanks John
Orich
1997 Expedition Power Lock Issues Supertommy68 2007 - 2014 Expedition & Navigator 1 07-15-2016 01:49 AM
99 7.3 Alt. Starter issues? NAMDROF 1999 to 2016 Super Duty 2 10-23-2014 11:35 AM
New battery drained...Help GT40NUT 1987 - 1996 F150 & Larger F-Series Trucks 32 08-30-2014 06:40 PM
HELP! Major elec. problem, Ex won't start, battery draw w/ key off 12valveEx Excursion - King of SUVs 10 08-16-2013 09:24 PM
Weird Electrical Problem in F250 Diesel Bigboy99 1999 to 2016 Super Duty 13 05-29-2012 08:34 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
