Clunking noise when over 60 ish. Front driver side
Got a 04' navi 4wd 230k on the dash.
I've got a clunking noise when over 60-65. Mainly when hitting bumps, even small bumps. Does not seem like in anything rotating (don't speed up when accelerating).
I've converting to springs a couple years ago as well.
I've replaced both away bar links alread as well last month. Still didn't fix it. Thought it could be upper ball joint. Tried everything I know to check ball joint. Doesn't seem to be loose. I've also thought when you feel a bad ball joint it's too late and usually breaks.
Any ideas?
Any ideas?
I notice a little bit of grease or something around the axle boot, but could be a little oil maybe.
I haven't looked at that. Should I be able to tell by looking how they are?
Only if they are obviously over-worn. It doesn't take much wear for them to clunk. If you replace them keep in mind there are 2 different diameter sway bars available so you'll want to measure that before ordering.
Thanks I may give that a shot, one of the sway bar links were broke several months back when I replaced them, being broke may have caused more wear on the bushings.
Ok to add more info to this since it still is having same problem.
I've noticed that it has a **** to place in 4wd. The **** has now a couple times moved by itself and will be in 4wd high. The **** is also in a weird position. Instead of the **** point directly at 2wd or 4wd it is turned counterclockwise about a 1/4 of a turn. Does it sounds like maybe axle or 4wd issue??
johngeorge
04-07-2013 03:33 PM
94' Ford
06-13-2004 06:30 AM
