Front Stabilizer Shock replacement - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 06-29-2016, 04:41 PM
Mikey11741 Mikey11741 is offline
Mikey11741 is starting off with a positive reputation.
Is there any particular front stabilizer shock I should purchase for a replacement for my 2003 X 6.0L diesel? Anything I should stay away from?
thanks,
Mike
Old 06-29-2016, 06:22 PM
WE3ZS's Avatar
WE3ZS WE3ZS is online now
World Famous Mod
WE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputation
I have the stock replacement Doorman steering stabilizer on mine with no complaints and I run 35" tires.
Old 06-29-2016, 09:28 PM
ok, thanks.
Old 06-29-2016, 09:56 PM
pirate4x4_camo's Avatar
pirate4x4_camo pirate4x4_camo is offline
pirate4x4_camo has much to be proud ofpirate4x4_camo has much to be proud ofpirate4x4_camo has much to be proud ofpirate4x4_camo has much to be proud ofpirate4x4_camo has much to be proud ofpirate4x4_camo has much to be proud ofpirate4x4_camo has much to be proud ofpirate4x4_camo has much to be proud ofpirate4x4_camo has much to be proud ofpirate4x4_camo has much to be proud of
An OE replacement will be fine if you are stockish. The Dorman will do the trick.
Bilstein also makes one or you could go with if you have 35"s the new Fox thru shaft setup if you have big tires.
These are a neat setup instead of running duals.
Old 06-29-2016, 10:07 PM
agsmv1's Avatar
agsmv1 agsmv1 is offline
agsmv1 is a name known to allagsmv1 is a name known to allagsmv1 is a name known to allagsmv1 is a name known to allagsmv1 is a name known to allagsmv1 is a name known to all
NAPA brand only lasted about a year for me, I have a Bilstein now.
Old 06-29-2016, 10:34 PM
mark996's Avatar
mark996 mark996 is offline
mark996 is gaining momentum as a positive member of FTE.mark996 is gaining momentum as a positive member of FTE.
I just replaced my OEM one with a Rancho when replacing all the shocks. No complaints, but when I do shocks again in 50-75,000 miles.
Old 06-30-2016, 06:44 AM
Jointasset's Avatar
Jointasset Jointasset is offline
Jointasset has a good reputation on FTE.Jointasset has a good reputation on FTE.Jointasset has a good reputation on FTE.
How does this work compared to the duals? When is there a need for duals? I have a single bilstein on my truck w slightly bigger tires while I have duals on the X and don't notice any difference.
Old 06-30-2016, 09:40 AM
Quote:
the reason for using dual opposition is that the larger high pressure dampers have enough rebound force to actually steer the vehicle if you only used 1, by opposing them it cancels that out since they push against each other.
The fox thru shaft allows you to use the large high pressure style "shock" but due to the design of the pass thru shaft it has equal force on compression and rebound so no need for duals.
When is there a need for duals ? When the OEM small one isn't cutting it. Depends on how and where you drive and the other mods you make but generally speaking 37"+ tires
Replacement stabilizer shock DieselVol 1999 to 2016 Super Duty 19 01-17-2014 02:27 AM
Anyone have experience with Moog stabilizer shock? FordTruckEnthusaist 6.0L Power Stroke Diesel 0 01-30-2013 02:30 PM
steering stabilizer shock? ChristopherN 1987 - 1996 F150 & Larger F-Series Trucks 15 12-29-2011 08:58 AM
Steering stabilizer...just a shock?? silly34 1999 to 2016 Super Duty 15 07-24-2009 07:39 PM
Replacement Steering Stabilizer Shock? mdwilli 1999 to 2016 Super Duty 30 04-21-2009 11:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
